| Diesel laptops Texa - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Diesel laptops Texa (/showthread.php?tid=3107) |
Diesel laptops Texa - mattb22 - 05-14-2018 Has anyone used texa and does it do everything insite does for Cummins. Thanks RE: Diesel laptops Texa - imalumberjack - 05-14-2018 (05-14-2018 )mattb22 Wrote: Has anyone used texa and does it do everything insite does for Cummins. pretty pricey RE: Diesel laptops Texa - mattb22 - 05-16-2018 Yes it is expensive but it is supposed to work on all makes which we need. Lot more expensive to buy everything separately. Just wondering if anyone has used it and if they like/dislike it. (05-14-2018 )imalumberjack Wrote:(05-14-2018 )mattb22 Wrote: Has anyone used texa and does it do everything insite does for Cummins. RE: Diesel laptops Texa - Waterloo - 05-16-2018 (05-16-2018 )mattb22 Wrote: Yes it is expensive but it is supposed to work on all makes which we need. Lot more expensive to buy everything separately. Just wondering if anyone has used it and if they like/dislike it.(05-14-2018 )imalumberjack Wrote:(05-14-2018 )mattb22 Wrote: Has anyone used texa and does it do everything insite does for Cummins. I would PM Unilever with this question. Their shop handles all of the manufacturers. RE: Diesel laptops Texa - tree98 - 05-16-2018 Quote:I would PM Unilever with this question. Their shop handles all of the manufacturers.Maybe a good idea but don't hold your breathe. He might not get back to you very.......... well ever ha ha ha RE: Diesel laptops Texa - Unilevers - 05-22-2018 it does not, it is very similar to jpro Uni |
