| Injector leak valve - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Injector leak valve (/showthread.php?tid=3111) |
Injector leak valve - fatbedsv77 - 05-17-2018 So I have a ISX15 (2250). early 2012. I am getting SPN 656 Injector Cylinder #6 (FMI7 Mechanical system not responding properly.) I have 483,000 and know Im due for an overhead. So my question is do I need a need an injector or will an overhead fix the issue possibly? Thanks RE: Injector leak valve - Nilao - 05-17-2018 I'm leaning towards an injector. The ECM could care less what your valve adjustment is. All ot knows is it told the injector to do something and it didn't listen lol. |
