| Cel fault 343 cm2350 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cel fault 343 cm2350 (/showthread.php?tid=3130) |
Cel fault 343 cm2350 - tree98 - 05-25-2018 Insite says ECM warning internal hardware failure - bad intelligent device or component. The driver said the truck ran fine all gauges read normal. It's now inactive with 1 count. Any idea's ? RE: Cel fault 343 cm2350 - Rawze - 05-25-2018 (05-25-2018 )tree98 Wrote: Insite says ECM warning internal hardware failure - bad intelligent device or component. The driver said the truck ran fine all gauges read normal. It's now inactive with 1 count. Any idea's ? What year make model truck? mileage? some history and detail? RE: Cel fault 343 cm2350 - tree98 - 05-25-2018 2018 Pete 365 (crane truck) cm2350 9,000 miles, factory original mandate. RE: Cel fault 343 cm2350 - Rawze - 05-25-2018 (05-25-2018 )tree98 Wrote: 2018 Pete 365 (crane truck) cm2350 9,000 miles, factory original mandate. If it sits a lot, maybe a ground wire or corrosion in a power supply somewhere? -- could also be battery backed mem module in ECM going bad and loosing memory if it sits a lot?. Just some abstract guessing here. Possibly have it re-flashed and see if it goes away?. RE: Cel fault 343 cm2350 - tree98 - 05-25-2018 Can I reflash it myself? RE: Cel fault 343 cm2350 - imalumberjack - 05-25-2018 (05-25-2018 )tree98 Wrote: Can I reflash it myself?2018? not under warranty? RE: Cel fault 343 cm2350 - tree98 - 05-25-2018 (05-25-2018 )imalumberjack Wrote:(05-25-2018 )tree98 Wrote: Can I reflash it myself?2018? not under warranty? It's under warranty but they aren't going to re flash it just because I ask them to. And I don't really want to take it there and let it sit for a week until they get around to poking and prodding it. |
