| Current draw key off - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Current draw key off (/showthread.php?tid=3182) |
Current draw key off - DosGatos - 06-05-2018 What should I expect for current draw with the key off and no accessories fridge or inverter running? Thanks (2011 prostar sleeper) RE: Current draw key off - Rawze - 06-06-2018 Maybe this helps... http://rawze.com/forums/showthread.php?tid=2748&pid=26925#pid26925 RE: Current draw key off - DosGatos - 07-12-2018 (Back home working on truck) 1.0 then .42. After 30 seconds or less .24 amp (2011 prostar high roof sleeper) RE: Current draw key off - Signature620 - 07-14-2018 If you think you have high draw, put an amp clamp on the battery cables and remove 1 fuse/breaker at a time until it drops significantly. Then you'll know atleast which circuit you're chasing. RE: Current draw key off - DosGatos - 07-14-2018 When I first tried with an inline ammeter I was seeing one amp and disconnecting. Didn't understand the current draw settles down if you give it time. RE: Current draw key off - snailexpress - 07-14-2018 after some time idling ECM goes to hibernate state same as any computer. |
