| Ugly fix - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Ugly fix (/showthread.php?tid=3189) |
Ugly fix - Oldad6150 - 06-07-2018 Is the ugly fix worth the time putting on my 2009 isx. It did work on my 14l Detroit obviously 2 different engines just curious if anyone had any luck with them. RE: Ugly fix - Chamberpains - 06-08-2018 Im guessing this is some sort of cheapo demandate doomed to trash the engine in short order. But im curious what it entails. Not to ever promote it or use it but to be just aware of what it is. If you can vaguely describe what it entails I'd appreciate the knowledge. If it is a demandate your after, your engine can be done very efficiently by you, a laptop, an inline adapter. Plus knowing how to properly program your ECM. There are a couple guys on here that can help with the last part. Some may contact you if your willing to ask. Or you can contact Unilevers, Mamaburt or I believe Mr. Hagg are in the business of taking care of this for you. Just PM them. RE: Ugly fix - Oldad6150 - 06-08-2018 Take the barometric sensor off and plug in the ugly fix to close the egr. Like I said on my Detroit it worked wonders cooled the engine down 15 degrees oil stayed clean for 10k. Now they have ugly fix for a Cummins but don’t want to install if gonna cause problems was just curious what was thought of it RE: Ugly fix - Unilevers - 06-08-2018 dont High altitude on ISX still have egr, so it will not shut the egr down. it will also not shut down the DPF or anything to do with that. What it will do is alter your injection strategy and combustion managers greatly and cause it to run like crap and have all sorts of possible failures. All ending in the destruction of your engine because you put that Barometric sensor tricker on there. Just dont, do it properly there are many options or leave it stock. RE: Ugly fix - Oldad6150 - 06-08-2018 Ok thank you RE: Ugly fix - Rawze - 06-08-2018 (06-08-2018 )Oldad6150 Wrote: Take the barometric sensor off and plug in the ugly fix to close the egr. Like I said on my Detroit it worked wonders cooled the engine down 15 degrees oil stayed clean for 10k. Now they have ugly fix for a Cummins but don’t want to install if gonna cause problems was just curious what was thought of it Even on the Detroit they are a bad thing. It shortens the life of the engine and causes over-boosting on them. it has been discussed here before... http://rawze.com/forums/showthread.php?tid=2351&pid=20332#pid20332 RE: Ugly fix - Oldad6150 - 06-11-2018 Yeah it went from 35 pounds manifold to about 45. |
