DPF wiring harness - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: DPF wiring harness (/showthread.php?tid=3191) |
DPF wiring harness - Overw8 - 06-09-2018 My 2008 prostar DPF wiring harness has magical green wire in it. I am trying to order a new one from Cummins, but they have no record of my truck have one. International can not find one either. I took a picture of the wiring harness tag but can not make out all the letters. Anyone else have this same truck with matching part numbers? Thank you RE: DPF wiring harness - Rawze - 06-09-2018 You can likely find some info on it by searching for "DPF Connector" in the wiring diagram ... http://bodybuilder.navistar.com/General/Documents/svcmanpdf/s08339.pdf RE: DPF wiring harness - Overw8 - 06-10-2018 Thank you I think I found it. |
