| Check engine light - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Check engine light (/showthread.php?tid=321) |
Check engine light - Braycross - 04-12-2016 Just wondering after getting turbo replaced truck regened 2weeks during blowed white smoke after idling for a bit. Now check engine light popped on and now it don't regen and no white smoke. RE: Check engine light - in2trux - 04-12-2016 It wont regen with cel on. You need to find out what codes are active. White smoke is from fuel collecting in the can. How many miles since the doc or dpf were cleaned? RE: Check engine light - Rawze - 04-13-2016 Start with an EGR tune-up. |
