Doser injector replaced - Printable Version
+--- Thread: Doser injector replaced (/showthread.php?tid=3294)
Doser injector replaced - Oldad6150 - 07-11-2018
I recently had my doser injector replaced at my local peterbilt and when done I asked them to run a forced regen to make sure everything was doing what it was suppose to they told me no need. Would it be recommend to do one now with insite like Mr. Rawze has shown on YouTube video
RE: Doser injector replaced - hhow55 - 07-11-2018
Yes, indeed.
RE: Doser injector replaced - Rawze - 07-12-2018
(07-11-2018 )Oldad6150 Wrote:  ..
they told me no need ...
Because they are incompetent, under-trained idiots.
RE: Doser injector replaced - Oldad6150 - 07-12-2018
I guess I should of demanded it quite honestly. But gonna run regen tonight
RE: Doser injector replaced - Nilao - 07-12-2018
Anytime the emission system is repaired they need to run a regen otherwise how do you know the part you just replaced is not defective or the issue is somewhere else.
RE: Doser injector replaced - dhirocz - 07-12-2018
Laziness. That's like paying someone to fix the AC in your house and the tech doesn't turn it on afterwards to make sure it actually works.
