| Overhead set tools - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Overhead set tools (/showthread.php?tid=3326) |
Overhead set tools - zero4 - 07-19-2018 Hey guys. Can you please help me out with the list of tools that is needed to perform the overhead set? Thank you. RE: Overhead set tools - Chamberpains - 07-20-2018 Watch Rawze's video. He shows you all the tools you need and why. https://youtu.be/gQprOKCVln8 Then get on Cummins Quickserve if your woking with a Cummins Engine https://quickserve.cummins.com/info/index.html and find out what size feeler gauges and torque ratings you need for your specific engine. RE: Overhead set tools - zero4 - 07-20-2018 Thank you very much Chamberpains! RE: Overhead set tools - Nilao - 07-20-2018 And the beer...no one ever remembers the beer. RE: Overhead set tools - 74bassman - 07-21-2018 Very inportant to have the beer. RE: Overhead set tools - Hammerhead - 07-24-2018 (07-19-2018 )zero4 Wrote: Hey guys. Sorry, I have been quite busy with work lately and haven't been active much and missed this. [attachment=4088] This is for an 871. 1)Dial tourque wrench w/ 8mm Allen head 2)1/2" torque wrench w/ 24mm socket ^these two are for the injector preload for CM871 and previous engine, not required for common rail motors^ 3)3/8" torque wrench w/ 19mm flare nut 4)1/4" torque wrench w/ 13mm flare nut I prefer flare nuts to crows feet, less chance of slipping off, but use whatcha got. 5)3/4" ratchet with short extension for barring over the motor I have T handle Allen wrenches, the 3 sizes are; 1)8 mm for injector 2)6 mm for valve adjusters 3)3 mm for Jake adjusters You don't necessarily need to have four different torque wrenches, I do so its just easier setting each one with its corresponding socket, crows foot, so I can just plow through. Check Post #2 of this thread, http://rawze.com/forums/showthread.php?tid=2279 It's a good thread, Waterloo, others and I also posted links of where to find some of these tools, at better prices than I did... |
