PLZ HELP 6.7 ISB REGEN DPF ISSUES - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: PLZ HELP 6.7 ISB REGEN DPF ISSUES (/showthread.php?tid=3327) |
PLZ HELP 6.7 ISB REGEN DPF ISSUES - Bighoss92 - 07-20-2018 I'm needing help with my 6.7 ISB Cummins that is in a stuck regeneration constantly. I have cleaned out the DPF filter that seemed to work for about 700 miles all good and dandy now ban right back into the Bermuda Triangle of generation I was wondering if anyone had this issue since I'm to the point of getting a priest and having an exorcism to get the demons out of this 6.7. It's in a 2010 Freightliner M2 business class:waaaht::@:@:waaaht: RE: PLZ HELP 6.7 ISB REGEN DPF ISSUES - Rawze - 07-20-2018 DPF problems are usually caused by engine excess soot problems. Start by going through the engine and EGR system and making everything clean + replace old sensors. RE: PLZ HELP 6.7 ISB REGEN DPF ISSUES - Moose - 07-20-2018 First you need to decide if this system is something you want or have to keep & fix or are you done with it. |
