DD15 overhead - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: DD15 overhead (/showthread.php?tid=3345) |
DD15 overhead - simon999 - 07-25-2018 Manual says to find tdc on first cylinder. Is there any marks like on cummins a,b,c..to find tdc? Also detroit requires special tool to bar the engine. Is this tool same for 2010-2018 engines? RE: DD15 overhead - hhow55 - 07-25-2018 Do you have a service manual. If not, maybe you find one on ebay RE: DD15 overhead - simon999 - 07-25-2018 (07-25-2018 )hhow55 Wrote: Do you have a service manual.I have one but its 2010. The truck is 2017. RE: DD15 overhead - uncleal13 - 07-25-2018 You don’t actually need that special tool, but it is more convenient to use. There is a small cover under the bottom of the flywheel. Open it up and just use a large screwdriver to lever it over. Okay for small moves, but for larger moves the tool is handy. RE: DD15 overhead - simon999 - 07-25-2018 (07-25-2018 )uncleal13 Wrote: You don’t actually need that special tool, but it is more convenient to use.I saw they sell one on ebay for $120 RE: DD15 overhead - Wrenching - 08-13-2018 The easiest way to get TDC on a DD platform is to line the marks on the cams up. RE: DD15 overhead - simon999 - 08-14-2018 Using timing tool right? |
