Trailer axle seals short life - Printable Version
+--- Thread: Trailer axle seals short life (/showthread.php?tid=3360)
Pages: 1 2 3
RE: Trailer axle seals short life - Rawze - 08-08-2018
(08-08-2018 )Redland1 Wrote:  ...
Synthethic oil boils at a much higher temp than regular oil and usually extends the life of the seal.
Don't know about others but if I had an axle or hub get hot enough to worry if it is synthetic or not, the type of oil would be the least of my concerns.
RE: Trailer axle seals short life - dhirocz - 08-08-2018
My company had a couple seals replaced on my tractor when I picked it up. They failed about 6 or 7 months later. I found out they never cleaned the spindle where the seal rides and it was rusty.
I always clean it off, take off the rust with crocus cloth, clean again and then lightly prelubricate, then be sure to properly set the preload. I have no more issues from mine.
I run stemco nuts. I found the instructions a bit vague so I called them. The instructions vary depending if you use the OEM cone as well, so you might want to call to verify.
