| miss 09 isx intermittant no codes - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: miss 09 isx intermittant no codes (/showthread.php?tid=3371) |
miss 09 isx intermittant no codes - shadowhunter - 08-03-2018 miss, puff of black smoke then all is good , no codes high mileage 800,000, changed filters all of them air fuel emissions, replaced turbo ,seized arm and actuator failed incite installation, looking at other areas , the article that rawze writes on the fuel timing and metering actuators are interesting any comments on those findings RE: miss 09 isx intermittant no codes - Chamberpains - 08-03-2018 They are simple to check and might only cost you a gasket. I say might because some came with reusable metal gaskets. RE: miss 09 isx intermittant no codes - Nilao - 08-03-2018 Egr valve sticking? |
