| engine fan - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: engine fan (/showthread.php?tid=3379) |
engine fan - slowpoke - 08-06-2018 going to replace engine fan today, anything i should now about looks simple enough. do i need to locktite the bolts? RE: engine fan - Signature620 - 08-06-2018 Just the fan blade? If you can, loosen radiator stays and shrouds to help with access. Pretty straight forward otherwise. RE: engine fan - slowpoke - 08-06-2018 okay thats what i did also had to remove intake pipe from cac to that pipe that says hot. was pretty simple once shroud was off. one new bolt was missing from top of shroud wonder if that hit fan blade and broke it small chunk was missing but no cracks. thanks signature620 |
