| incal - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: incal (/showthread.php?tid=3423) |
incal - tdawg - 08-18-2018 anyone know where I can get an incal disc that will work with insite 7.6. Im running a 2005 isx and need calibrations because I changed motors. RE: incal - Marajin - 08-18-2018 make 7.6 read newer cal file. * Add extension '.zip' to end of calibration file name. Unzip newer cal file with 7zip from 7zip.org using the appropriate password. Older zip utility will not unzip it, only newest 7zip program will due to new zip128 encryption. The password can be found on the interwebs, not going to post it here in forum. * re-compress it back with regular old style zip format without any password at all. * Remove the .zip extension and Set the name of file back exactly as its original name again. 7.6 will then read the newer file just fine. RE: incal - tdawg - 08-18-2018 I don't have any of the files. RE: incal - Marajin - 08-18-2018 (08-18-2018 )tdawg Wrote: I don't have any of the files. https://insite.cummins.com/Files/ECM_Calibration_Download_instructions.pdf or. https://www.cummins.com/parts-and-service/electronic-service-tools/incal |
