| fifth wheel wrecker - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: fifth wheel wrecker (/showthread.php?tid=3437) |
fifth wheel wrecker - bauer2568 - 08-20-2018 ive seen a standard truck pulling another truck with a device that hooks the fifth wheels together. im having trouble figuring out what they're called, searching fifth wheel wrecker gets results that cost 7-8000 dollars. im trying to find the simplest, cheapest, option to have in case i ever break down i can tow my truck home myself since i run local, and im sure the dot would have a field day if i was caught towing it with a chain lol RE: fifth wheel wrecker - Nostalgic - 08-20-2018 $7-10k seemed to be the ballpark when I looked into them. Once in a while you'll see one listed for less, but they go quick. Unless it's a long distance recovery, that would buy a lot of short tows. |
