Bypass connection thread size and pitch - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Bypass connection thread size and pitch (/showthread.php?tid=3479) |
Bypass connection thread size and pitch - dw2000ta - 09-01-2018 Need to know the thread size and pitch to get hoses made for my bypass oil filter. Block off plug above the oil Pan and the plug on the oil cooler housing. Any help greatly appreciated I have three hours to get it done before the shop closes Don't have the option to pull it off and compare. I'm driving it RE: Bypass connection thread size and pitch - dhirocz - 09-01-2018 14mmx1.5 on the cooler, 18mmx1.5 on the block. O-ringed fittings. I used 1/2 NPT to 5/8 JIC on the filter housing. |
