Schafers oil - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Schafers oil (/showthread.php?tid=3484) |
Schafers oil - Bbtrucking - 09-02-2018 Has anyone ran schafers oil..is the added cost worth it? Thanks RE: Schafers oil - stevesparts - 09-02-2018 I think it would be too costly to run in the motor,as most change to oil at 10 to 12 thousand miles but in other parts like diffs or trans use a good oil in them. I spent the $$$'s on putting in amsoil(my choice) in my diff's/trans. but just run good old Rotella 15/40 in the motor as i change it often, and i do run a bypass filter too. just to trying to keep the oil clean as possible. and i do add gear oil (gl4) too :) for the added protection. RE: Schafers oil - Volvo8873 - 09-02-2018 “The best oil money can buy is a fresh oil change” RE: Schafers oil - Waterloo - 09-02-2018 Rotella. RE: Schafers oil - dhirocz - 09-02-2018 Fresh oil is the best oil. I'll change it early before I change it late. |
