| Cm2250/2350 injectors?? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2250/2350 injectors?? (/showthread.php?tid=3494) |
Cm2250/2350 injectors?? - jimeneztrans84 - 09-05-2018 Just wondering why the cm2250/2350 injectors fail and leak? I've had 3 injectors fail in 3 years 2 of them in less that 3 weeks apart. Cheapest I got the dealer to sell me oem cummins rebuild is $850. I've heard of rebuild injectors sell for $450 with 6 month warranty. Are you guys using oem rebuild or other company rebuild? So far what I've read on this forum is to only use cummins rebuild. RE: Cm2250/2350 injectors?? - dhirocz - 09-05-2018 OEM only here. RE: Cm2250/2350 injectors?? - Rounded_nut - 09-10-2018 OEM rebuild, thought about new but carries the same warranty, which does not inspire confidence. RE: Cm2250/2350 injectors?? - jimeneztrans84 - 09-11-2018 Looks like I'll just stick to cummins reman. |
