Power Steering pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Power Steering pump (/showthread.php?tid=351) |
Power Steering pump - PuroCumminsPower - 04-22-2016 I will be changing my Power Steering pump this weekend, if any one can give me some insight on the procedure they followed I would really appreciate it. Thanks. RE: Power Steering pump - RPM1 - 04-22-2016 (04-22-2016 )PuroCumminsPower Wrote: I will be changing my Power Steering pump this weekend, if any one can give me some insight on the procedure they followed I would really appreciate it. Thanks. i always add the oil after its changed , but that's just me :) RE: Power Steering pump - PuroCumminsPower - 04-29-2016 I changed pump and added oil. I started it and at first I couldn't even turn steering wheel. I shut truck off , waited tried again and it turned real easy. Day after I left to work and its hard to turn again. Its when I'm at a complete stop and its worse when turning left. Steering wheel makes noise as well. I have to give it a little fuel to turn easier. I had gear box changed about a year ago. Any ideas? RE: Power Steering pump - snailexpress - 04-29-2016 (04-29-2016 )PuroCumminsPower Wrote: I changed pump and added oil. I started it and at first I couldn't even turn steering wheel. I shut truck off , waited tried again and it turned real easy. Day after I left to work and its hard to turn again. Its when I'm at a complete stop and its worse when turning left. Steering wheel makes noise as well. I have to give it a little fuel to turn easier. I had gear box changed about a year ago. Any ideas?Power steering manufacturer has filling procedure on web. Search it. RE: Power Steering pump - PuroCumminsPower - 04-29-2016 If i have air in system how would you recommend i get it out? RE: Power Steering pump - Unilevers - 04-29-2016 what box or boxes do you have? it varies. RE: Power Steering pump - PuroCumminsPower - 04-29-2016 I have a A H Sheppard gearbox. EDM power steering pump. Its on a 2009 International PROSTAR. RE: Power Steering pump - snailexpress - 04-29-2016 https://www.youtube.com/watch?v=uRjSSpoOnH8 |
