| ISX primer pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX primer pump (/showthread.php?tid=3522) |
ISX primer pump - earnies2 - 09-12-2018 How difficult is it to change the primer pump can it be done in the truck 2009 international prostar I did an oil change and she wouldn't start wire to pump hot and pump hot.... RE: ISX primer pump - Starlight - 09-12-2018 Fairly easy, need about a t30 torx bit for the bolts unless they've been updated to a regular hex head. Would also be a good time to replace the check valve in the ifsm housing once the pump is off. Maintenance thing. RE: ISX primer pump - Rounded_nut - 09-12-2018 As said above, easy peasy! On my 2350 it's two straps securing it, remove inlet/outlet and disconnect the harness. |
