Spn157 / fmi 18 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Spn157 / fmi 18 (/showthread.php?tid=3537) |
Spn157 / fmi 18 - Breeze - 09-16-2018 Hey guys , this code has reset and jow wont stay gone , i have read up on it and understand what it is saying , just where to start, i do have insite on board with me , im just not very sure where to go in diag area , any help would be appreciated , my isx has 700,000 miles on her and she is a hard worker , we are in morority at the ta not wanting these guys under her hood , we can remote hook up if anyone cares to give a look and help a guy out . Thanks in advance RE: Spn157 / fmi 18 - fargonaz - 09-16-2018 Does it run? did you change the fuel filter? RE: Spn157 / fmi 18 - Chamberpains - 09-16-2018 If you have Insite, go to the help menu and then troubleshooting tree and follow the troubleshooting guide. Or right click on the code in insite and bring up the troubleshooting tree. Your gonna do a far better job diagnosing this than a TA monkey. RE: Spn157 / fmi 18 - Breeze - 09-16-2018 (09-16-2018 )fargonaz Wrote: Does it run? did you change the fuel filter? Am waiting on that as we speek , yes it runs , seems as it started after i changed the oil and fuel filter 3000 kiles ago i was hopeing somthing wrong with the fuel filter or seperator filter so thats where we are starting .. RE: Spn157 / fmi 18 - Breeze - 09-16-2018 (09-16-2018 )Chamberpains Wrote: If you have Insite, go to the help menu and then troubleshooting tree and follow the troubleshooting guide. Or right click on the code in insite and bring up the troubleshooting tree. Your gonna do a far better job diagnosing this than a TA monkey. Thanks sir after we get the filters replaced just for grinns , ill hook up the insite and give it a go .. |
