erg tune up - Printable Version
+--- Thread: erg tune up (/showthread.php?tid=357)
erg tune up - jesse20 - 04-25-2016
when cleaning the pipes should i remove the tempature sensor from the top pipe were the egr valve is or can it stay on the videos doesn't say
RE: erg tune up - hhow55 - 04-25-2016
Remove, you don't want any chemicals to come in contact with the temperature sensor.
RE: erg tune up - jesse20 - 04-26-2016
(04-25-2016 )hhow55 Wrote:  Remove, you don't want any chemicals to come in contact with the temperature sensor.
will do thanks
