3 Piston Fuel Pump to 2 Piston Swap Parts. - Printable Version
+--- Thread: 3 Piston Fuel Pump to 2 Piston Swap Parts. (/showthread.php?tid=3613)
3 Piston Fuel Pump to 2 Piston Swap Parts. - RaideRue - 10-10-2018
I have a question so I recently bought a new gear fuel pump for my isx since my old one took a dump.
Im noticing that there are 3 lines that connect in different locations of the new pump.
2 being the ones behind and under the pump by the frame.
And 1 on the fuel pump head.
Tried to ask the dealer but they were no help per usual.
Wondering if anybody has done it and has part #s for these new lines that I need to buy. Thanks in advance. Much appreciated it.
Below are 2 photos of the old pump and the new one
RE: 3 Piston Fuel Pump to 2 Piston Swap Parts. - Rawze - 10-10-2018
Mr. Hag has done a lot of them. Maybe he, or someone else can chime in with the right part#'s to do the swap-over.
here is the thread you got the pictures from, might be some info over there as well ...
http://rawze.com/forums/showthread.php?tid=668&pid=5739#pid5739
RE: 3 Piston Fuel Pump to 2 Piston Swap Parts. - Signature620 - 10-10-2018
If you have quickserve access (you should sign up if you don't) here's the installation manual including all the steps, tensions and parts for the job.
https://quickserve.cummins.com/qs3/pubsys2/xml/en/install_inst/4907962.html
RE: 3 Piston Fuel Pump to 2 Piston Swap Parts. - RaideRue - 10-10-2018
(10-10-2018 )Signature620 Wrote:  If you have quickserve access (you should sign up if you don't) here's the installation manual including all the steps, tensions and parts for the job.
That link had everything, thank you...
if anybody else does this in the future and goes from the older style 3 cylinder fuel pump to the new 2 cylinder pump the parts in that link from quickserve will be needed as mounting brackets are different for each pump..
all the parts listed on that link came out to a grand total of $523 the guy at the dealership said i probably wasnt going to use all of them..
tomorrow once i do the pump swap i will update here and mention all the parts that i used.
thanks evrybody for their input
