| Cm871 cylinder 4 smoking really bad - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm871 cylinder 4 smoking really bad (/showthread.php?tid=3624) |
Cm871 cylinder 4 smoking really bad - Husky05 - 10-14-2018 Hello all, my truck started to smoke like a chimney, idle is little more rougher now, did cylinder cut out test in insite and with number 4 off it doesn't change the idle but stopped the smoking. Does that mean injector number 4 is bad? RE: Cm871 cylinder 4 smoking really bad - Nilao - 10-14-2018 Most likely you have a hole in that piston...take off the oil fill cap and check blowby. Im betting it smokes heavily from there too. RE: Cm871 cylinder 4 smoking really bad - Husky05 - 10-14-2018 No smoke coming out of blowby tube and oil fill cap. Engine has about little over 40k miles on inframe with new head which includes all internals in the head including all 6 injectors. RE: Cm871 cylinder 4 smoking really bad - Rawze - 10-14-2018 (10-14-2018 )Husky05 Wrote: Hello all, my truck started to smoke like a chimney, idle is little more rougher now, did cylinder cut out test in insite and with number 4 off it doesn't change the idle but stopped the smoking. Your engine was slated for premature failure by the abusive programming it had in it ... http://rawze.com/forums/showthread.php?tid=3565&pid=30900#pid30900 The problem(s) you are now having may very well be damage that bad programming may have already done to it. Hopefully it is only an injector or something simple. Move the injector to another cylinder, boroscope the cylinder(s) + check the valves and valve seats while you are at it. some related info: http://rawze.com/forums/showthread.php?tid=1632&pid=18718#pid18718 |
