freightliner oil pressure. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: freightliner oil pressure. (/showthread.php?tid=3641) |
freightliner oil pressure. - Vanhvacr - 10-19-2018 hello all, I have 2013 freightliner cascadia with isx15 cm2250. I have engine oil rifle pressure and keep show low oil pressure at about 19psi at 1400rpm. one a while it shut off the enginee. I have to restart the truck back on again. replaced- oil pump, oil pressure sensor, oil check valve, oil temp sensor, oil changed. please help thanks best regard! RE: freightliner oil pressure. - Rawze - 10-19-2018 http://rawze.com/forums/showthread.php?tid=3604&pid=31085#pid31085 and... http://rawze.com/forums/showthread.php?tid=3424&pid=29494#pid29494 RE: freightliner oil pressure. - Vanhvacr - 10-19-2018 thank you very much sir. |
