Tapping/knocking sound - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Tapping/knocking sound (/showthread.php?tid=3647) Pages: 1 2 |
RE: Tapping/knocking sound - Lonestar10 - 10-21-2018 If the guys I'm least I'm with keep up with the 3500 to 4500 after expenses weeks I might just have to start replacing components so I know what shape everything is in RE: Tapping/knocking sound - smorgan87 - 10-21-2018 Is this after u demandated it? RE: Tapping/knocking sound - Lonestar10 - 10-21-2018 No it was there before RE: Tapping/knocking sound - akwman - 10-25-2018 (10-21-2018 )Waterloo Wrote:(10-21-2018 )Lonestar10 Wrote: I do not know on the dampener I'll have to have that checked out thank you very much What might that equate to hours , does anyone know ? RE: Tapping/knocking sound - Rawze - 10-26-2018 (10-25-2018 )akwman Wrote: What might that equate to hours , does anyone know ? 10,000 - 15,000 hours? RE: Tapping/knocking sound - Lonestar10 - 10-26-2018 my truck has right at 28,000 hrs with 1,031,000 also has an APU, Update on this issue. now that truck is demandated...i can hear a miss or burp in the exhaust note when idling and accelerating before the turbo fully spools. need to see if my mechanic has the cummins injector leak test tool or if i can find someone on here to 3d print one for me..... truck runs on single cylinder test so this is the last test i can think of to try. when previous owners overhauled it they only put in 1 new injector now i need to get ahold of Intl and find out which one. called cummins 6300 after core returns for 4 actuators and 6 injectors...damn highway robbery... so ied wrather see if i can find the problem with the tool. RE: Tapping/knocking sound - Lonestar10 - 10-29-2018 well just replaced my davco filter for first time since i bought the truck as it was 3/4-7/8 the way up on filter and filter was black since i biocided the tanks..... waiting or guy to get to waly world to load me with carboard. i think international needs to send their techs back to school....... truck was annual inspected/serviced by them when i bought the truck. brought truck home after purchase 3 lights out ...fixed trailer air supply line plastic line blown/pulled out of push to connect fitting....fixed can on driver side front brakes pancake blown....fixed passenger side rear airbag leaking...fixed now that i just did filter...pulled top cap out of bowl....2 o-rings where there should be one.. for the love of god the indescribable incompetence. RE: Tapping/knocking sound - Rawze - 10-30-2018 (10-29-2018 )Lonestar10 Wrote: well just replaced my davco filter for first time ... I hope you put a 10-micron filter in it instead of the 50-micron that most idiot oil change places use. |
