| dd15 2013, what rpm should i idle at? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: dd15 2013, what rpm should i idle at? (/showthread.php?tid=3661) |
dd15 2013, what rpm should i idle at? - Vanhvacr - 10-25-2018 hello I had a 2013 freightliner cascadia dd15. Can you somebody help me set my idle, rpm, in diagnostic link 8.07? what rpm should i idle at? thanks you best regard. RE: dd15 2013, what rpm should i idle at? - Lonestar10 - 10-26-2018 650-700 - when i drove a 2016 casc dd15 it idled at 650. unlike my cm871 it likes 725 clutch is jumpy at 650. thankfully i can set my constant idle speed with cruise controls instead of constanly changing it in insite. RE: dd15 2013, what rpm should i idle at? - bossboy2 - 11-02-2018 I believe mine is set at 650. Watch your oil pressure. RE: dd15 2013, what rpm should i idle at? - Vanhvacr - 11-02-2018 (11-02-2018 )bossboy2 Wrote: I believe mine is set at 650. Watch your oil pressure. your set at 650rpm, what is your oil pressure at after enginee warm up? thanks you, |
