| Insite 7.5 diagnostic tests not working - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Insite 7.5 diagnostic tests not working (/showthread.php?tid=367) |
Insite 7.5 diagnostic tests not working - 389driver - 04-27-2016 Hey guys... I'm running Insite 7.5 just because it's always worked for me and I never had a reason to update to 7.6 It's always worked fine for me up until now. When I try to perform a diagnostic test like a cylinder cutout or performance test it won't do anything. I highlight which test I want then click "Next" but nothing will happen. Do I need to update to 7.6 or am I missing something? I set up a CM871 simulator connection and it has the same problem, so I don't think it is a problem with my calibration in the ECM. I have 2 laptops running 7.5 one with XP the other Win7 and they both are having this problem. I'd like to get this figured out so that if I ever need to remove my turbo actuator I can recalibrate it. Right now that function is dead along with all the other diagnostic tests . Thanks in advance for any help! RE: Insite 7.5 diagnostic tests not working - barf - 04-27-2016 Upgrading to 7.6 is a real PIA to go back to 7.5. It sounds to me like your INSITE is only running in 'Lite' mode. I'm running 7.5.0234, just ran it and I don't see how to run in simulator mode. I'm too lazy to connect to truck right now. RE: Insite 7.5 diagnostic tests not working - Nilao - 04-27-2016 Working for me in simulator mode...check your licenses... RE: Insite 7.5 diagnostic tests not working - 389driver - 04-27-2016 Thanks for the replies. I uninstalled, deleted the installation folder and ran CCleaner on the registry. Reinstalled in the default install directory and got it working. |
