13 Fl cascadia dd15 fan clutch not on... - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 13 Fl cascadia dd15 fan clutch not on... (/showthread.php?tid=3692) |
13 Fl cascadia dd15 fan clutch not on... - Vanhvacr - 11-02-2018 Howdy Al, I am back, My 2013 freightliner cascadia with dd15 with 651,728 miles on it back. new fan clutch, fan selenoid test: air to fan clutch, power to selenoid key on, fan unlock key off, fan lock My temperature is at 210f and the fan still not work. Did i do something wrong? thanks you all for the advise. Best Regard. RE: 13 Fl cascadia dd15 fan clutch not on... - Lonestar10 - 11-02-2018 typically the fan will not turn on till around 215-220 for full clutch on a 2016 cascadia i drove even my cm871 wont engage the fan clutch till somewhere north of 210 RE: 13 Fl cascadia dd15 fan clutch not on... - bossboy2 - 11-02-2018 It is colder now. RE: 13 Fl cascadia dd15 fan clutch not on... - Vanhvacr - 11-02-2018 (11-02-2018 )Lonestar10 Wrote: typically the fan will not turn on till around 215-220 for full clutch on a 2016 cascadia i drove even my cm871 wont engage the fan clutch till somewhere north of 210 let me double check on it again, thanks you |
