International Tractors - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: International Tractors (/showthread.php?tid=3713) |
International Tractors - AHMLLC - 11-07-2018 Im looking in to buying a 06 international tractor with a cummins ism. Is it true INTERNATIONALS are prone to electrical problems? Is there anything I can do to be proactiv? Also, are 06 ISM's good engines? I plan on tuning the EGR unit if i ever get it. Rawze is the best! RE: International Tractors - Chamberpains - 11-07-2018 All trucks are prone to Electrical problems. Some worse than others. Being it's an 06 it'll be a lot simpler than the newer trucks. I have an 2006 9400i and it's still what I'd consider in the "basic" truck wiring world. You can get most International wiring diagrams and schematics for free online. I think it's under Truckbuilder or something like that. I had to buy mine on Ebay for $30. But well worth it to have wire codes and plug layouts. RE: International Tractors - DVT873 - 11-07-2018 other RE: International Tractors - AHMLLC - 11-07-2018 Basic is a plus. Thank u guys. Thoughts on ISM? RE: International Tractors - Shack0313 - 11-13-2018 I had a 06, put 1,600,000 on it it was an awesome truck, no electrical problems really Headlight plus would rought out, , new ones where 25$ each |
