| Crankcase pressure/volume build up - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Crankcase pressure/volume build up (/showthread.php?tid=3718) |
Crankcase pressure/volume build up - Makmak - 11-08-2018 I have competed a blow by test for my ISX871 850K (Correction..it has a second motor mileage supposedly 600k) As per Rawzes blow by test video. As I increased my rpm slowly to 1500 the difference in the water level kept increasing and oil was coming out of the dipstick. I have checked for the usual blockage related stuff...crankcase filter..blow by drain tube..etc What can cause continual building of crankcase pressure? I suspect the turbo but how would I test for that? I have not performed a compression test. Engine runs smooth. I performed a cylinder cut out test with Insite and it seemed okay. I'm at a loss! RE: Crankcase pressure/volume build up - Rawze - 11-08-2018 (11-08-2018 )Makmak Wrote: I have competed a blow by test for my ISX871 850K mileage. maybe drill out the crank case filter so it can;t build pressure and hurt the turbo? http://rawze.com/forums/showthread.php?tid=65&pid=376#pid376 RE: Crankcase pressure/volume build up - Makmak - 11-08-2018 (11-08-2018 )Rawze Wrote:I have already drilled a hole in the CC filter. While doing the blow by test all that was bypassed as you know. What is the max size file size of a video I can upload to here?(11-08-2018 )Makmak Wrote: I have competed a blow by test for my ISX871 850K mileage. RE: Crankcase pressure/volume build up - Chamberpains - 11-08-2018 Upload it to YouTube and then post a link on here. RE: Crankcase pressure/volume build up - Lonestar10 - 11-13-2018 i do beleive an air compressor can also throw pressure into CC RE: Crankcase pressure/volume build up - Makmak - 11-15-2018 (11-13-2018 )Lonestar10 Wrote: i do beleive an air compressor can also throw pressure into CCI checked yesterday I do have oil coming out of the compressor discharge port. RE: Crankcase pressure/volume build up - Rawze - 11-15-2018 (11-15-2018 )Makmak Wrote:(11-13-2018 )Lonestar10 Wrote: i do beleive an air compressor can also throw pressure into CCI checked yesterday I do have oil coming out of the compressor discharge port. that could cause a lot of issues with the air systems later on. |
