Cam/Rocker Condition - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cam/Rocker Condition (/showthread.php?tid=3786) |
Cam/Rocker Condition - Philroy - 11-22-2018 Can anyone give me any information on this cam/rockers based on these photos. Like its condition ect. Its in a isx15 450 2350 x101. I have a few additional photos. Just from a bit further off. RE: Cam/Rocker Condition - Philroy - 11-22-2018 I decided to include the additional pics. RE: Cam/Rocker Condition - Unilevers - 11-22-2018 looks like dirt staining except for the last pic of the first post. WTF did you blow off the gasket area and around the cover before you took it off? It looks like a ton of dirt fell in there from the valve cover removal. while the first pics are not great, its very typical and unless you can catch it with your fingernail its fine - BUT CLEAN OUT THE LAST PIC OMG IT LOOKS LIKE THE DEEP END OF THE SANDBOX IN THERE!!! RE: Cam/Rocker Condition - Philroy - 11-22-2018 Thanks for the reply. They all felt pretty smooth no catching with a fingernail. It was cleaned out to the best of my ability before the cover went back on. What tipped me off to my lack of proper cleaning was a few tiny red paint specs in a couple of the photos. Stuff that small is hard to see with the naked eye. It is amazing what a high resolution photo shows. RE: Cam/Rocker Condition - rrod - 11-22-2018 How many miles ? I have the same engine with 398k and the cams look somewhat similar. Had the same concern. RE: Cam/Rocker Condition - Philroy - 11-22-2018 430k miles Cummins just did an overhaul at 411k under the excessive oil consumption campaign. I just bought the truck and wanted to make sure the top wasn't about to destroy its self. RE: Cam/Rocker Condition - imalumberjack - 11-23-2018 Yeah, i'm with unilevers on first glance at last pic it looks heavily pitted then you look to sides and you can tell its dirt everywhere. I think on cummins quickserve they give you a gauge as to what's exceptable wear and when to replace. That being said I would run it. RE: Cam/Rocker Condition - Signature620 - 11-23-2018 They call them white bands. Nothing to worry about. |
