| '06 Mack 460 ASET - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: '06 Mack 460 ASET (/showthread.php?tid=3788) |
'06 Mack 460 ASET - DLC - 11-24-2018 Anyone with Mack engine experience? Mack engine has an intermittent EGR code. There is very limited information on repairing it or providing a permanent solution. First time I had a look at one of these engines. A lot different than an ISX. Goofy blow off valve on intake to bleed excess boost into exhaust. RE: '06 Mack 460 ASET - Nilao - 11-24-2018 I think mack uses the engine out of a volvo...its the same as the d13 i think. RE: '06 Mack 460 ASET - RPM1 - 11-24-2018 07 i think is when the mp series came out , mp engines are like the volvos , there should be 2 buttions on dash in front of steering wheel that give u the blink codes , and u can google for the codes and how to get them . Gear head i belive has worked with mack stuff . RE: '06 Mack 460 ASET - DLC - 11-26-2018 Correct 07 engines are Volvo. Not much out there as for information and trouble shooting. Not a huge market for the solutions industry. Thanks |
