Cm570 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm570 (/showthread.php?tid=3802) |
Cm570 - Jmac0586 - 11-29-2018 Will the cams and rockers from a cm871 fit a cm570? The cm570 was reconed in 2007. The cm871 is a 2009. Tia RE: Cm570 - the missing link - 11-29-2018 As far as I know , yes . But I don't know much . RE: Cm570 - Pd6cas2 - 11-29-2018 Cummins quickserve will answer this question. Have both engine serial serial # and learn on! |
