Turbo exhaust leak - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Turbo exhaust leak (/showthread.php?tid=3810) |
Turbo exhaust leak - DosGatos - 12-02-2018 871 w/holset turbo leaking under clamp. I assume I'm going to r&r a gasket. Anything I should be aware of and any source for miscellaneous parts? [attachment=4466] RE: Turbo exhaust leak - victory26 - 12-02-2018 As far as I know there is no gasket there. That part of the turbo is being sealed with some type of glue, I heard someone calling it cement. RE: Turbo exhaust leak - Nilao - 12-03-2018 There os a brass or copper ring in there....make sure you mark the position of the housing so you can get ot clocked back in the right position. RE: Turbo exhaust leak - Rawze - 12-03-2018 Yes there is supposed to be a sealing ring there instead of a gasket. |
