Exhaust gas pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Exhaust gas pressure (/showthread.php?tid=3849) |
Exhaust gas pressure - Lostfarmboy - 12-09-2018 I just had a question on my forced Regen. I was looking at the exhaust gas pressure and was wondering if there is a normal range. Mine runs in the 160 to 170 range and was wondering if this was normal. RE: Exhaust gas pressure - Lostfarmboy - 12-09-2018 apparently I'm having a problem with my boss regen it's been a half an hour twice and my aftermarket injector has never come on has anyone ever run into this problem? RE: Exhaust gas pressure - Lostfarmboy - 12-09-2018 Shut the truck off and restarted insite. All good with the forced Regen now. RE: Exhaust gas pressure - Lonestar10 - 12-09-2018 if your engine is not reaching operating temps it wont start. when they replaced a buncha parts on my truck before i bought it they couldn't get it to do a forced regen so they went to throw parts mode. first they pulled doc/dpf baked it flow tested 2nd replaced aftertreatment injector 3rd replaced sensors on doc/dpf 4th and finaly replaced turbo and actuator and supposidly this fixed it and it did a forced regen 80k later i bought the truck and it would regen every 2hrs had high pressure readings and now all mm'ed and finaly got a injector leak test kit and think i found problem the 1mil mile injectors blowing air bubbles backwards like mad 10x worse then on rawzes video of that 386 or 387 pete. but would still run on 1 cyl with cyl cutout test. so this friday here comes 6 new injectors. funny thing truck doesnt really idle/drive bad but its 500HP and sometimes i swore the 2016 detroit 450hp i drove for crete had more power and i thought the 2012 450hp maxxforce prostar i drove before that had more power then the detroit lol. RE: Exhaust gas pressure - Lostfarmboy - 12-09-2018 Sounds like mm was the way to go. RE: Exhaust gas pressure - Lonestar10 - 12-09-2018 it was for me as i semi refuse to spend money on equipment that can hurt a 25,000$ engine. that if properly cal'd as i trust in all those here that have helped me its cleaner then most trucks/cars/pickups on the road that arent forced into these dreaded systems. im all for clean air but not at the expense of emptying my pocketbook to do it. |
