| 444XT O rings - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: 444XT O rings (/showthread.php?tid=3859) |
444XT O rings - RocketScott - 12-10-2018 Cummins 444xt NT855 I bought a gasket set from PAI. It came with a couple bags with a few dozen orings each, not labeled of course. There are some that are the same size. Some are black and others green. They are the size I need for both the fuel crossover tubes and the oil supply inside the head. Any suggestions about which goes where? The orings I pulled out were black on the fuel and green on the oil supply. So many things have been wrong on this truck that I don't trust that's correct |
