| 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! (/showthread.php?tid=3870) |
2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - rtayl328 - 12-12-2018 Looking for info on 2006 Oil Pan Gasket Replacement. 1. Is there a gasket upside (to the block) or downside (to the pan) I should be aware of? 2. Is there a particular bolt pattern to use? ( Circular, just doesn't sit well in thought.. Pan is to large... I think! ) 3. Use Silicone? Top side ( Block ), Silicone ( Pan Side ) or both? 4. Recommended silicone for reused oil pan, if any? 5. How much silicone to use, if any? 1/16 bead outside perimeter. All help provided will Truly be Greatly Appreciated... Thank You, R. Taylor RE: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - hhow55 - 12-12-2018 Go to Quickserve.cummins.com, and you will find the info you need RE: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - rtayl328 - 12-12-2018 10-4. Thought, I needed E/SN to access after registering.. But forgot to get it while at yard today.. Thanks for the info.. RE: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - Signature620 - 12-13-2018 Oil pan gasket will fit correctly in all possible orientations. Small bead of silicone in each corner where the block joins the flywheel & gear housings (block side only). Tighten the bolts in a circular or middle-out pattern, whatever you like - up to 35ftlb. RE: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - rtayl328 - 12-13-2018 Thank You Signature.. The old guy went to work again today and left yard without getting the ESN.. I even had the hood open to blow out air to air and Filter,, ETC... Still closed the hood without even thinking about it... RE: 2006 ISX, 475, Oil Pan Gasket... HELP... PLZ!! - imalumberjack - 12-14-2018 Other than whats been said: I tried to reuse old ....it leaked. On the corners make sure you scrape old silicone off first. |
