|  exhaust sound - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: exhaust sound (/showthread.php?tid=3876)  |
exhaust sound - opey450r - 12-16-2018 i have a 07 pete 379 with 565. have 7 inch straight pipes and when it get to around 1500 rpm it has a weird sound up in till 1700. has anyone else had that problem. we have a 05 tractor with same motor with same pipes but it doesn’t have that sound. no exhaust leaks all brand new from y pipe out. hard to explain noise with words. when you back off throttle a little bit the sound goes away and sounds like it should RE: exhaust sound - marek4792 - 12-16-2018 Is it like a hum that resonates? RE: exhaust sound - Lonestar10 - 12-16-2018 ive noticed when pulling with mine after about 1550 the engine tends to get a sort of harmonic resonance sound engine almost sounds like its running better at that point and higher but no real change in power. RE: exhaust sound - opey450r - 12-16-2018 no it sounds almost like an exhaust leak then goes away. kind of like motor gets out of wack the comes back no power loss just sound completely different at those rpms RE: exhaust sound - Rawze - 12-16-2018 (12-16-2018 )opey450r Wrote: i have a 07 pete 379 with 565. have 7 inch straight pipes and when it get to around 1500 rpm it has a weird sound up in till 1700. has anyone else had that problem. we have a 05 tractor with same motor with same pipes but it doesn’t have that sound. no exhaust leaks all brand new from y pipe out. hard to explain noise with words. when you back off throttle a little bit the sound goes away and sounds like it should Is the truck de-mandated? if so, who did the work? how much boost is it making when it does this? RE: exhaust sound - opey450r - 12-16-2018 no she’s factory and around 35psi  |
