| Help! invasion of the black crud - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Help! invasion of the black crud (/showthread.php?tid=3878) |
Help! invasion of the black crud - imalumberjack - 12-16-2018 So fuel filter clogged (new) and yep it was black crap! I had seen threads here and as this truck had been parked for several years I kept kinda looking but didn't see any evidence ......until today ....looked on interior back wall and it has a black layer on it! I take it this is the dreaded algae? Questions: I bought a jug of Biocide ..should I drain tank and flush? How heavy is a 140 gallon tank? can I wrestle it in pickup by myself? Will I need to flush fuel lines? ECM? RE: Help! invasion of the black crud - Lonestar10 - 12-16-2018 you can super shock the algae if its that and not asphaultine and just carry a few extra fuel filters onboard. my truck came out of minneyota so it ran a lot of biodiesel which i tend to like truck seems to run better when i find a B20 blend pump. but it had algae so far Ive ran 2 harsh treatments of bio-cide and have only killed 3 fuel filters in 2 months. Ive never pulled tanks but i would think a 140gal aluminum tank would probably be in the 100-150lb range. RE: Help! invasion of the black crud - Evotrucker - 12-16-2018 build a pump to polish the fuel or just drain it completely and fill them up half way and dump half a gallon in each tank let it sit for a day. that should help a lot with the algae in the tanks and bring 3 or 4 filters with you. i change my water/fuel seperator filter about every 3 weeks.... its not great but what can i do about it. Good luck dude!. |
