| Front end wobble/ shake - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Front end wobble/ shake (/showthread.php?tid=3912) |
Front end wobble/ shake - race7820000 - 12-23-2018 I have a 9200 international that will get into a death wobble or shake when you go around a curve, when your going down the road straight you can feel a slight shake, very minor but if you have to fight the side wind and turn the wheel a little it starts into its shake. It did it durning a run last week. We checked front wheel bearings and they feel fine, checked King pins and the pass side has some play. I've seen way worse and the driver side feels tight. We took it up to the interstate and got it up to speed and the pass side front wheel looks like it's moving side to side going down the road. I was in my pickup becide him. Tires look like they are wearing even, we balanced them and checked for run out. It was aligned 6 months ago, all the steering linkages seem tight. It's driving me nuts because it did it light a light switch. When it does wobble or shake its so severe that it's going to destroy the truck. It only does it from 55 mph and up. You can barley feel it at 45-50 RE: Front end wobble/ shake - pearce trucking - 12-23-2018 Bad passenger tie rod end? RE: Front end wobble/ shake - Rawze - 12-23-2018 check tie rod ends and spring shackles?. check caster alignment? RE: Front end wobble/ shake - race7820000 - 12-28-2018 Ended up being a bad tie rod. Evidently you need to check them jacked up in the air, once I jacked it up it had all kinds of up and down movement. And I had a vibration after and noticed the driveshaft was out of phase. Fixed all that and replaced all the u joints and now she is new again |
