2010 389 PETE FIREWALL PASS-THROUGH CONNECTORS - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: 2010 389 PETE FIREWALL PASS-THROUGH CONNECTORS (/showthread.php?tid=3946) |
2010 389 PETE FIREWALL PASS-THROUGH CONNECTORS - bazdan902 - 01-02-2019 Hello folks, Looking for some guidance on how to get p/n#'s for the firewall pass through connectors on a 2010 389 Pete? I had troubles a couple years ago with tail lights, re pinned and cleaned up the plugs on the firewall. Plastic was getting brittle, it needs to be redone but my local dealer was unable to find the part numbers, the other week I began having issues again so I'd like to do a proper job this time. I'm assuming they are made by Deutsch and can be found that way? I'd like to re do inside and out on all PASS-THROUGH connectors. Any info is appreciated Thanks |
