| New 2007 Pre Emission Series 60 14L - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: New 2007 Pre Emission Series 60 14L (/showthread.php?tid=3959) |
New 2007 Pre Emission Series 60 14L - AHMLLC - 01-04-2019 07 Columbia 140 Series 14 L 668k miles I plan on buying this truck tomorrow and I need to know is there anything I need to check for specifically? I got the guy down to 12k and its a repo truck. Should i be wary? What engine updates should I do as soon as I get the truck? Any help is good. RE: New 2007 Pre Emission Series 60 14L - Waterloo - 01-05-2019 Break out your check book... Unless you own a shop and tools, and know how to use them... No clue what you are buying with the info you have given... I have around $120,000 in my 2008 ProStar, not including lost wages and actual purchase price of said vehicle, but it was and still is a "special" truck. Good luck. And yes, I am drinking. But, the truck still has a clear title! LOL! RE: New 2007 Pre Emission Series 60 14L - Waterloo - 01-05-2019 Here you go... Used turck Buyer Beware by Rawze https://www.youtube.com/watch?v=tTu6cr1d1Lc Watch the video... I wish I had knew of Rawze before purchasing my EPA used truck. RE: New 2007 Pre Emission Series 60 14L - imalumberjack - 01-07-2019 Repo'd trucks can be good or bad. Consider that the person was more than likely out of money and not doing any maintenance. If the shop that's selling thought it was in good shape they would want more ....that's the first and second red flags. Like waterloo said you must be able to work on it yourself, and you may have to work on it before it ever makes a penny ....... matter of fact you should plan on it. RE: New 2007 Pre Emission Series 60 14L - tree98 - 01-07-2019 For $12K consider it a scrap truck for parts. If it ends up being more than that consider yourself lucky. If it doesn't, you got what you paid for. RE: New 2007 Pre Emission Series 60 14L - AHMLLC - 01-07-2019 I went to see the trunk and the owner had tape around where the fuel tank cap should be.No deal RE: New 2007 Pre Emission Series 60 14L - Lonestar10 - 01-07-2019 repo truck either 1 of 2 things basically - owner ran the truck into the ground which then inturn ran him into the ground. or 2 owner took good care of it then got sick/died whatever... basically is what ied say the 2 points would be. |
