isx 870 overhaul - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: isx 870 overhaul (/showthread.php?tid=3987) |
isx 870 overhaul - rgreen - 01-10-2019 I have a friend that has 870, He just had it overhauled and his truck has less than 300 miles on the major overhaul and he's now finding oil in fuel filter, also the mechanic never counterbore the block, also he had oil leak coming out from the value cover also the fuel tanks now has oil soot inside of it. Prior to having his truck inframe he took into Cummins and they told hold him his block was fretted. RE: isx 870 overhaul - Unilevers - 01-10-2019 i feel the pic of the pink dildo coming! he needs to get it to someone competent RE: isx 870 overhaul - rgreen - 01-10-2019 (01-10-2019 )Unilevers Wrote: i feel the pic of the pink dildo coming! I have been told him that when i have informed to take to a machine shop to have them couterbore it and set the liner height, but do you know where to start to looking for this oil mixing in with the fuel. RE: isx 870 overhaul - hhow55 - 01-11-2019 Go to quickserve.cummins.com Click on service link, then, symptom search, and you will see what to do. |
