flash codes 2019 pete ?? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: flash codes 2019 pete ?? (/showthread.php?tid=3996) |
flash codes 2019 pete ?? - tree98 - 01-12-2019 Anyone know how to get flash codes out of a 2019 pete 567 cummins X15? it's an emmission related problem. RE: flash codes 2019 pete ?? - imalumberjack - 01-12-2019 (01-12-2019 )tree98 Wrote: Anyone know how to get flash codes out of a 2019 pete 567 cummins X15? it's an emmission related problem.mine is a little older but if you turn key on (not start) let computer cycle, then depress throttle to floor 3 times it will flash the code at you. RE: flash codes 2019 pete ?? - tree98 - 01-12-2019 I tried that, it just turns on the wrench light and the red stop light, then it says "do not start engine damage will occur" RE: flash codes 2019 pete ?? - imalumberjack - 01-12-2019 (01-12-2019 )tree98 Wrote: I tried that, it just turns on the wrench light and the red stop light, then it says "do not start engine damage will occur"have you looked for a diagnostic switch in cab? |
