| De-mandated... Sensor Question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: De-mandated... Sensor Question (/showthread.php?tid=4004) |
De-mandated... Sensor Question - bossboy2 - 01-15-2019 It's coming up on a year since I changed the IMAP in my DD13. After a de-mandate, does that sensor still need to be changed? RE: De-mandated... Sensor Question - Rawze - 01-15-2019 If the computer in a vehicle does not know the accurate intake air pressure and temp, then it cannot magically calculate the proper fuel-air mix. incorrect reading IMAP = effeciency losses. worse case scenario... A person replaces it and no changes in engine operation or efficiency occur ... They now have a spare sensor in for use in troubleshooting, or to give to someone else to see if it fixed a problem they might be having. I am a hypermiler, so I replace mine once a year just to ensure I am not loosing soemthing. |
