big scare oil pressure freakout - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: big scare oil pressure freakout (/showthread.php?tid=4019) |
big scare oil pressure freakout - MageRoyal - 01-18-2019 big scare few days ago. Oil pressure goes to 0 and engine alarm. pulling over, oil pressure comes back. Then 1 min later oil pressure goes to 100psi and alarms again. Engi running fine. beep beep beep beep all night long. oil gauge peged. next day dealer open and i replace sensor myself in parkinglot while they yell at me for opening hood with wrench in my hand. all is normal again. I though engine was blowing up. New oil pressure sensor seems to have fixed it. My stomach was upset all nite. RE: big scare oil pressure freakout - Pd6cas2 - 01-18-2019 Same thing happened to me ,One morning startup engine no oil pressure 0 psi , I immediately shut off engine . Then I checked oil level and took cap oil filler off, started up truck and I had blowby pressure. Then I could breathe, got a ride to stealership sensor replaced ,All is good. |
