placement of jack stands front end prostar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: placement of jack stands front end prostar (/showthread.php?tid=4038) |
placement of jack stands front end prostar - DosGatos - 01-22-2019 not sure where I can set jack stands under front of a 2011 prostar. would like to let the suspension hang and look and shackles, bushings and the like. there is a cross member at the front of the frame rails but doesn't look sturdy enough to support 12k. behind the shackles would mean an increase in weight bearing load. I have 6 and 12 ton stands. rails are blocked by the leaf springs so where to go? thanks in advance. RE: placement of jack stands front end prostar - smorgan87 - 01-22-2019 Crossmember in front of engine |
