|  ISX 2350 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX 2350 (/showthread.php?tid=4065)  |
ISX 2350 - sstrong1 - 01-28-2019 I have code 3936 FMI 15. Anyone know what this is? It says delta p circuit sensor. RE: ISX 2350 - MommaBurt - 01-28-2019 Details for Cummins fault code: 1981 SPN FMI Lamp Color Description 3936 15 Amber Aftertreatment 1 Diesel Particulate Filter System - Data Valid But Above Normal Operating Range - Least Severe Level Reason Aftertreatment Diesel Particulate Filter System - Data Valid But Above Normal Operational Range - Least Severe Level. The aftertreatment differential pressure has exceeded the maximum operating limits or the diesel particulate filter is plugged. Effect Possible reduced engine performance. Component Location The aftertreatment diesel particulate filter is located in the exhaust system and is installed by the original equipment manufacturer (OEM). Refer to the OEM service manual. Circuit Description The engine aftertreatment system monitors the soot load in the aftertreatment diesel particulate filter. Under normal operating conditions, the aftertreatment diesel particulate filter is self-cleaning, where soot is converted to carbon dioxide, nitrogen, and water. Under light load operating conditions, it can be necessary to perform a stationary regeneration of the aftertreatment diesel particulate filter. The soot load in the aftertreatment diesel particulate filter is estimated, using the aftertreatment differential pressure sensor and the calculated soot output of the engine. Basically, the filter is a little plugged.  |
